100/1 or 50/1 oil mix
nwcove
Re: 100/1 or 50/1 oil mix
Mix it 100:1 and add a splash more, I always use a couple extra tablespoons of oil just because, you don't have to jump right to 50:1, doubling up on oil is kind of extreme but just a bit more will give you a little more oil but not enough to cause a problem, call it 90:1
i would personally go with 50:1, and a bit of seafoam (75:1 at bare minimum)........but if you're going with 100:1,add the splash more oil for peace of mind.
pecheux
I think I have read somewhere on this board that outboard Mfg's engineers knew what they were doing ... does that include Yamaha's ..LOL Now seriously if Yamaha recommends 100:1 mix ratio I would presume it would be using THEIR 2 cycle oil ??
nwcove
.......does everyone use brand specific oil?
5150abf
In reallity there are very few places that make oil so say Pennzoil will make and rebrand oil for 10 different companies, the formulations may be a bit different but it is still Pennzoil, I believe thay make the Super Tech that Wal Mart selss which alot of people on here use with absolutely no problem.
I run the Super Tech or if I am in a hurry and out of oil I will use the 7-11 brand which here again is made by somone else and put in a 7-11 bottle, as long as it says it meets TCW-3 standards it is fine so you can pay 40 bucks a gallon or 13 but it is pretty much the same oil.
And I run an '81 Evinrude 50, if I had a brand new 250 something I might be tempted to go up market a bit but for an older lower output engine the cheaper stuff is fine.
aerobat
the OP claimed by itself that the engine has been running on 100:1 without any issues so i think there is no need for discussing if the engine will accept this ratio or not
beyond that its a question of personal preferences. if you , running at 100:1 , cannot stop thinking about seized pistons use 50:1 - if you, running 50:1 , cannot stop thinking about fouled plugs and sooted rings use 100:1 .
i have a 5 hp 2000 yamaha kicker and never had any issues with 100:1 - and the plug is unchanged since two years. our marina has a pontoon with a 6 hp yamaha as workboat, also running 100:1 and also without any issues.
the recommended ratio will have margins for different operations and also some mixing mistakes- using the double amount of oil than recommended is from a technical point of view not a win situation, but like said- when you feel better with it , go for 50:1 , the engine will surely run with this mixing.
best regards !
