Stromzilla
Thread starter- Joined
- May 2, 2009
- 47
Apparently I wasn't qualified to speak on behalf of recommending using a quality oil designed to run at 100:1 ratios in premix-only applications. Well I'm back with some experience and the experience continues to build. Background first: The motor is a 1979 Evinrude 115hp 2-stroke. Unfortunately I hit a snafu with the engine when I discovered the gel seal had failed so I had to rebuild the engine entirely. What I discovered was a pretty disgusting carboned up mess, especially in the exhaust area but also 3 of the 4 pistons had rings that were locking up creating a blow-by situation which ultimately would have been a total disaster. Based on my experience with 2-stroke motors in general, and I have a fair amount of that (thank you very much), the heavy carbon buildup is from using cheap oil that flashes off too soon and that includes some TCW rated oil. The carbon I pulled out of my engine was 1" deep (in some areas) and had the consistancy of coffee grounds. So you guys running that cheap crap from Walmart beware, it simply isn't worth it and you'll ultimately pay the price, and I'm speaking to those running at 50:1 ratios. This engine by the way had been split open before to replace a piston that siezed probably due to a dirty carburetor or cheap oil causing a ring to lockup. Anyways the engine has been running just fine on 100:1 with very little smoke at idle. Startups are a breeze and it idles easily down to 500 rpm without missing a beat. The plugs have been checked twice and both times they showed to be burning very cleanly. To date I've only run about 40 gallons of pre-mix. I know, my skeptics are saying that's not enough so I will continue to report out as I progress through the summer. However, so far the old Evinrude performs no differently than all my other 2-stroke motors that I own that have been running on 100:1 for many years without issues. It really is impressive.
