100 HP Outboard T-Stat Question
l_striker
Can anyone tell me (or provide a diagram) where to find the t-stat on my 1988 Merc 100 HP outboard?
HD Fatboy?
Re: 100 HP Outboard T-Stat Question
If it is like my 115 I don't think it has one.
l_striker
Does your 115 spit water through the "tell tale" on a cold start, in netural, using muff's? I just changed my impeller, ruled out a hose blockeage, and nothing is coming out. I was thinking the t-stat could be stuck shut since the boat was always used in salt water.
Dave1027
Looking at the back of the motor, it's at the upper left corner, next to the #1 spark plug. You'll see a cover about 4 or 5 inches long which houses two circular objects. The small object on top is the t-stat. The larger in the bottom part is the poppet valve.
Dave1027
Before you go too far you should first consider the more simple and more likely causes. Remove the tell tail nozzle and blow compressed air backwards through it. Those nozzles clog all the time.
l_striker
Thanks. I removed the hose and blew compressed air through it without an issue. I also blew it the opposite way just to be sure. The one thing I didn't do is replace the gasket on the water pump but it should spit out a little bit of water though even if it's no 100% sealed, right? By the way, I made sure the impeller was facing the right way and that the key was in place.
Dave1027
Nope. The tell tail should be squirting water even with the t-stat closed. Mine begins squirting within 10 seconds of a cold start. This is in the water not on muffs, but I don't know if it makes a difference.
l_striker
I wouldn't think so but stranger things have happened. One more question, is swapping out the t-stat pretty straight forward? The impeller was a breeze.
Dave1027
Looks pretty easy but why do you still think the problem is the t-stat?
l_striker
At this point I'm at a loss of what else to try next. I figure for $10, even if it's not the problem, it couldn't hurt to change it. I'm thinking about dropping in the water to see if it works but I'd hate to go through all of that effort if it doesn't. Any other suggestions would be greatly appreciated!
