1000SS Shift Shaft??
Cogburn
I bought a 1968 1000ss yesterday. I bought it pretty cheap for a project motor as it ran ok,
BUT...
The shifter would shift into neutral when shifted towards reverse. Otherwise it was in forward gear.
I thought that maybe the selector shaft might be out of time-no big deal. After 2 hours of screwing around I came to the realization that the shift shaft coupler splines are worn out. The shift shaft only engages about less than 1/2" of the selector shaft coupler and they are about gone.
When I line everything up and then shift it it just skips a tooth or two and doesn't work.
Is this a fairly common problem?
I think it is a 47326A1 Shift shaft. Coupler 93960A1??
Does this thing screw on or???
Cogburn
Re: 1000SS Shift Shaft??
Well...
I bought a couple couplers and backed the boat I bought with the 1000SS on it in the shop to remove the coupler.
The coupler was welded on the shifter shaft from the factory-not replaceable.
I pulled the powerhead to remove the shifter shaft, found an allen wrench that fit the coupler and proceeded to cut it,a sleeve,and the shaft down on my lathe to make a shaft that would accept the coupler.
I think that I have a decent shaft to use now but I have to pick up some gaskets for the powerhead and exhaust divider. Hopefully I have the hex clocked pretty close so it shifts properly.
Quite alot of work to replace the shifter shaft.
I did clean out the accumulated carbon in the exhaust.
I think I may replace the lower crank seal while I have the powerhead out. I s this a good idea since it has been in there since 1968?
Does anyone have a pic of what they use for an engine stand??
