100hp Mariner trim problems
littlefuzz
The serial # is OB346653. I had to take the cylinder off to fix another problem now I can't seem to get all of the air out of the system. I raised and lowered several times but if I raise it to far it won't come back down on it's own, I have to open the valve under the pump and let it down a little then it'll power down. I thought it was supposed to be self bleeding from other posts I've read but it don't seem to be working. I've searched for the process to bleed the system but couldn't find a definative answer. Can anyone help?
AMD Rules
Re: 100hp Mariner trim problems
Do you have a 3 ram or a single ram version? Both were available for that motor.
littlefuzz
I guess you would call it a 3 ram. It has the single cylinder in the middle and it trims down and sits on the other two cylinders when it slows down.
