Re: 10ga wire for Minn Kota 45lb PowerDrive V2
Silvertip, it is sometimes very hard to explain to folks that have no knowledge of how electricity works and how big cables have to be to eliminate voltage drop to their trolling motors per the current draw. People just don't realize that only so much current can flow through certain size wires. I sometimes try to equate a water hose to the current flow situation... Same with the hose diameters too. Take a 25’ hose that is ?” in size (diameter) and measure the water pressure at the end. Then take a ?” hose and measure the water pressure at the end too. Both will read the exact same pressure. Now fill a five gallon bucket and time it with both hoses. See the differences...? Water pressure is basically the same as voltage. And water flow is equal to current...
