11 TOOTH GEAR and 9 TOOTH GEAR same starter?
betayv
hi there i have a 1979 mercruiser 228/305 with a alpha one, my starter went bad so I took the starter out and went to the marine store then they try to sell me a starter look the same but is a 11 TOOTH GEAR my is a 9TOOTH GEAR they guy told me that will work that the 11 tooth replace the 9 I kind of dont believe that, if anybody have some info please thanks.
Re: 11 TOOTH GEAR and 9 TOOTH GEAR same starter?
Ayuh,.....
Basically,...
SBCs can have only 1 of 2 different starters,+ which starter is determned by the Block's drillings,+ the flywheel.....
It's Either the Straight Across bolt pattern,...
Or,...
The Staggered bolt pattern....
Whatever 1 you took Off,... Put the Same bolt pattern back on,+ it'll Work.....;)
betayv
hi there ok the one they try to sell to me look the same that my old starter is the Straight Across bolt pattern but like I sai the one was on the boat before is a 9 tooth starter and the new is 11 that will make a diference, Im asking because I work for automotive and for example for cars you cant use the 11 on the 9 tooth or aeither the 9 on the 11.
chiefalen
Maybe new style starter.
Uses less juice to turn.
Just don't forget to put the bracket that holds the front of the starter on.
Or the starter bolts could snap.
If they looked it up, and the #'s match, the bolt pattern match it will work.
Good luck!
