110 evinrude 1989 problem
ciacione
I have 1989 evinrude 110 hp,gose fine up to half way the trottle after that dies down almost dead and then piks up speed for ten second and then dies again all day long.I have a new power pack,plugs,fuel filter,fuel lines,can anybody help please??????????
kybill66
Re: 110 evinrude 1989 problem
Hold in your choke when it bogs down and if it picks up you have a fuel problem if it dies the fuel is ok and another thing you can try is if you have a 6 gallon gas tank you can hook it up and limate the fuel system from the boat to the motor.
kenmyfam
Same symptoms I got when my fuel pump started to fail. Does it pick up if someone squeezes the primer bulb while it is doing this ???
cdoliver
clogged carbs, weak fuel pump, blockage in the fuel line before the pump, or blocked tank vent.
