havoc_squad
- Joined
- Mar 5, 2011
- 739
Hmm... couldn't find, or didn't look at all possible causes
See how it runs, they may have corrected it with replacing the cam follower, it will affect the Pickup Timing as it changes the Snyc between the Carb and Timing Advance and less than smooth performance can happen
I'm suprised there wasn't some signs of pre-ignition/detonation going on due to the ignition timing advance much more than the fuel/air supply did from the transition from idle to intermediate.
I would also guess that your carb throttle arm was not fully open due to the outter roller missing, hence why WOT fuel was not achieved.
I do know that whether two stroke or four stroke, you can identify hesitation issues by dropping the hammer in idle to safe WOT speed run under load. Then compare the behavior from idle at load with a slow progression of the throttle.
It helps to identify the behavior/symptoms of each stage of fuel/ignition.
If you have an issue with intermediate stage of throttle, what affects it?
Ignition timing, whether all spark on all cylinders not missing, intermediate fuel jet.
