115 Etec hard miss
Volphin
Have a 2007 115 Etec that has a hard miss with low idle (it's so hard it almost feels like a physical hit when cold). Upper throttle positions are better, but the tach still twitches a bit like she is cutting out on a cylinder. This is a new boat to me and I have outboard experience, but not with the OB EFI units. Past records indicate: fuse blowing on startup, a replacement of #3 injector, then later an entire engine controller. Looks to me like someone has been chasing this condition for some time. Ideas?
Honorary Supreme Mariner
Doubt that E-TEC uses optical ignition.----Drained gear oil ?
Crosbyman
suggest you visit the ETEC ownner's board with ETEC questions... you need EV diagnostics on a w10 laptop to look-see inside the EMM computer ...
first thing to look at is the fault log for active faults.
blowing 10 amp fuses are frequently assoc. with bad EMM $$$
private sale or dealer dale ... any warranties...??
ETEC are complex machines and you need the service book . ask user GEB
check bacic stuff... filter fuel pressure on the injectors, lift pump screen ...
try some EVinrude engine cleaner in a fresh tank
