evinrudedad
Thread starter- Joined
- Jul 12, 2014
- 7
I have a 79 Evinrude in 115 hp. Great motor has not given me one bit of problems until this year. I took it out on the pond and it was running full speed not WOT but close so RPM's were not maxed. All of sudden it lost allot of power like I throttled back but I hadn't. I thought it was fouled plugs I replaced them. Took it out again ran fine until I shut it down. Went to go full speed after trolling with my kicker same thing again. It will idle but does not have power past half throttle. Took it out again today wide open it was running great backed it off a little bit and it fell on its face wouldnt plain or nothing. If i run it at full warmup it struggles to. it will max out the rpms on warmup normally now it wont get past 3000. I think my high end jets are plugged but not sure. I tried the fuel tank from my kicker and it had no change. Also when I unhook the fuel lines I hardly see any fuel come out like its not pressured up in the motor. I also took the fuel screen off to see if that was plugged it was very clean. I seen a similar post where someone squeezed there primer bulb at wot to give it more fuel I havent tried that yet. I did find a coil wire that has been cut and spliced back together but it has a good connection not soldered like it should be but pretty good. Any help would be appreciated.
