HypnoCraft
Thread starter- Joined
- Aug 30, 2018
- 94
Hi Guys,
My evinrude recently started having a cough or misfire of some sort. at idle and high speeds. idle its a single cough every once and a while and at highspeed it a sputtering and loss/surge in power.
The issue is intermittent.
I pulled the spark plugs and they are all fully black and slightly wet with oil. The spark plugs are less than 4 hrs of run time new. I recently swapped them from NGK to UL77V Champions. That is all that has changed since last season.
Another thing is that there is a residue of gas and oil in the engine compartment. It seems to be coming from the exhaust housing, so a seal job may be in my future.
I am about to start trouble shooting the ignition system, but I read a post that said the ignition trouble shooting is outdated in the manual. how do I go about checking the pulse pack? mine is original, so I am thinking the manual's method will work fine?
Also, if anyone has any ideas on what may be causing this problem, please let me know.
