I'm trying to get this old Johnson to run right again. Any help would be appreciated. The general symptom is that when I get it into the water and increase the throttle, it will not go over 2500 rpm and the boat won't plane out. I did get it to plane out once for a while, but then it dropped back to a lower rpm. The last time I took it out, again, it would only get 2500 rpm at w.o.t., but then something happened where I could not give it any more throttle past 1500 rpm or it would die.
This is what I have done, so far. I did a compression test and all 4 were between 105 and 110psi. I checked the timing at idle, checked for spark at each cylinder, tore down the carbs, which looked perfectly clean with no sign of varnish, replaced all the spark plugs, and I ran all the tests I could in the SELOC manual with a standard volt/ohm meter. The one thing that did not meet specifications was that the resistance on the charge coils was reading about 305 ohms, on both coils, and the spec was over 500 ohms +/- 75 ohms. Could this be causing my problem? I didn't want to buy this part, which is a fairly expensive assembly, unless I had confidence it would fix it. One reason I hesitate is that both charge coils were reading exactly the same, which I would think is unlikely that both would fail to the same value. I have not checked the spark when under load, but it seems to run smooth, it just doesn't rev up. The charge rectifier also checked out. When running it I would squeeze the priming bulb which would be stiff and have no effect.
I am about ready to take it to a mechanic, but I would like to get some input from some of you with experience so that I can fix it myself. I appreciate any of your suggestions.
grw5
grw5
