reynold460
Thread starter- Joined
- Apr 25, 2008
- 103
hi guys i have a 115 hp merc outboard serial number oc106992 i recently rebuilt the powerhead and was putting everything back together i went to put the shift cable back on and i tried to slide the shifter into neutral it will go into neutral but it wont stay in neutral but it will go into forward and reverse fine .
when i went to put the powerhead on the shift lever was turned way out of its normal travel , did i turn the shift lever the wrong way ? is this possible ? thanks for any help you guys can give in advance
