115 Johnson idle RPMs????
V4 Johnson
Could someone give me the idle RPM spec for a 1984 Johnson 115 V4??
I got no manual with the motor. From about 800-1000 RPM on up to 5500 it runs like a Swiss watch. But it wants to stall at idle, which the guy had set at around 500 RPM. Is it idling too slowly?? Or might it be a timing or mixture issue??
Thanks for your help.
Daviet
Re: 115 Johnson idle RPMs????
700-800 rpm in the water in gear.
wilde1j
650 should be fine, again in gear in the water. 500 is too low to expect the motor to run.
V4 Johnson
Thank you very much, kind sirs!! ;)
I appreciate it greatly.
