Re: 115 mariner surging at high rpm
That is correct, this engine is a 2+2 setup where the top 2 carbs are only used at idle, thus they are the only ones with idle screws on the port side at the top of the carb, there is a hole in the throttle cam to access #2. If carbs are good, look into the stuff mentioned before. Good luck. BTW, I've got a 96 mariner 115.
