hoosiercaver1
Thread starter- Joined
- Nov 15, 2009
- 36
I recently bought a used Cdi switch box for my 1970 115 mercury. I installed it per the installation guide online. Once I had it all together I preceded to put some fresh fuel in and try.to fire it up on the hose. It started easier than ever before. I was going to take it out today so I hooked to the hose and.made sure.it was fire and run before hauling it to the lake and it wouldn't start. So I got to looking at it and noticed that it was arcing from the coil to the front plate where the unit mounts to. It also seemed jump from the coil to the terminal where the lead from the switch box tells.the cool to.fire. I.since put a larger deeper boot.on the.high.tension lead on the.cool. I also notice.the.screws that hold the cool to the mounting plate were loose and.i.thought that might have cause.the arcing since the coil gets it's ground from the screw on the mounting plate. Now I am not getting any.spark and I hope I didn't burn up the Cdi box when it arc ed to the switch box. It also sounds like a pop when I turn on and off the key. Any ideas on what to do would be great. Thanks John
