Hi all,
I have what i believe is a 1965 115hp inline six mercury. I noticed water being very intermittent coming out of the tell tale exit in the cowl. I thought maybe it was a bad impeller. I took the lower unit off & inspected the impeller...looks like new! So then i thought maybe there was some foreign material plugging it. I found nothing. When I blow compessed air into the tell tale outlet it then works for maybe 15 seconds as well as if I raise the rpm'sit also works for a short time. The power head stays cool enough to hold your hand on the cylinders so I know its getting some sort of cooling. Any ideas how to make this work again? Thanks in advance guys!
