115 mercury 1982 no power when in high gear
kcjones
Hi all. Im haveing some trouble with this eng Its a 115 merc 1982 6 cly. Redid the carbs all of them have new gaskets new everything on carbs New fuel lines and tank and inline fuelfilter, At low rpm runs great but give it gas and it don't want to get up and go, checked compretion and all are at 107 to 110 sparkplugs are new and so is the fueul tank. What else should I do to it to check for anything else that might be doing this to the eng? any help would be great and thanks for reading this , Have a great day.
K C Jones
canoemang
Re: 115 mercury 1982 no power when in high gear
If you have verified spark.. not just new plugs i would look into DVA testing the electronics.
Could be high speed end of stator..
DVA/CDI Electronics link
K.C. Does the motor die just above idle speed, or at say 2500RPMs? If just above idle, you likely set your idle mixture too lean. Richen them up a bit, top carb first and test beterrn adjustments. If it dies above 2500RPM, maybe it is ignition problem.
