Hi guys have a question about my 77 inline 6 tower of power, Serial number is 4701195.
I rebuilt the carbs and the boat runs really well now. Only problem I have is when I shift into gear the motor stumbles and then dies. It will do this unless I play with the fuel enhancer to get it going.
My inital settings for the carbs were 1 1/2 turns out on each carb. It runs good at this setting, however I did turn each carb out an additional 1/8 turn just so I was not running too lean and take a chance of burning a piston.
Is this a good procedure I should stick with or should I turn the carbs back to 1 1/2 and then lean it out alittle more to get the stumble out of the engine when taking off?
I also rebuild the fuel pump and installed a new water impeller.
Any help would be appreciated.
BTW I did perform the Timing and Sync procedure.
Troy
Troy
