Abomb27
Thread starter- Joined
- Jan 6, 2013
- 141
Hi, I have a four winns fling that is running lean. I can't get the idle below 1900rpm. When I try to lower the idle it starts to stutter then die. I am adjusting it on the hose, does that make a difference? I just replaced the fuel line and water separator filter. I haven't tried to start it yet. I rebuilt the carbs two weeks ago, but I forgot to adjust the float heights so I am going to take the carbs off and adjust the floats. Is there anything else I should be checking out adjusting to correct this problem. Thanks. Trying to get on the water for memorial day weekend.
