TurboJet
Thread starter- Joined
- Jul 13, 2015
- 75
Afternoon all,
After looking over the engine a few more times while I have it on the bench, I think I have noticed the cam follower rollers for the carb/advance are "missing" the roller sleeve.
I have successfully found part number 0432572 for the advance "roller, cam follower", but I can't seem to find the part number for the carb side folllower.
Although I can not find the part number, having a second set of carbs has proved useful and I have a spare cam follower, but I am curious as to what the part number is for it?
The first attached pic is the original follower, and the second is the one from the donor carb.
Also, you can see in the 3 position pics the roller sleeve missing from the advance follower.
(It also looks like I may need to adjust the linkage and the pics showing the positions are before i swapped the carb side follower into place, but it seems to run fine the way it is, so I may not tweak it, just replace the rollers?)
Any insight helps!
Any insight helps!
