I have a year 2000 Yamaha 115HP ? V6 - 2 Stroke. The low oil safety mode intermittently activates. No horn just the indicator light on the dash aluminates and the motor rpm limit activates. Both oil reservoirs are at least half full. I had the shop check the wiring and they replaced one wire but it didn?t change the problem. They also changed the controller, that seemed to work for a little while but the problem came back. Could I be a bad level switch in one of the tanks, if so how do I check that? Also, is there any way to override this in a pinch?
