Re: 115A fault code
Are you in the 3+1 year warranty? If so, a dealer can help. Did you reset the TPS per the Factory service manual? You need a bigger battery; 1,000 cca. If the problem persists, and is a "failure in TPS #1", you may need to re-seat the connector, and/or replace the tps. If it's just a "wrong position of tps 1", the reset should clear the error.
