Re: 115hp 1977 #5 & #6 sprak plugs are clean
You're absolutely right, I didn't think to ask the obvious question, 'are 5 & 6 actually running?'
Also, are there signs of water on the plugs or are they just "washed" clean?
If no signs of water and those cylinders aren't firing, there certainly could be ign issues.
Couple other things to think about, fuel pump diaphragm leakage flooding the cyl's or issues with the bottom carb, doing the same.
Anyway, more info would help get to the bottom of the problem which May or May Not be water intrusion!............ed
