Re: 115hp fin bent
If there is any cracking, it will break.
A mild bend can be straightened. You need to use a large hammer on the backside to act as a anvil and absorb the shock wave. My preferred hammers ara a small 2-3lb sledge as the anvil and a midsized deadblow to hammer with.
Move the anvil hammer around, not awlays in the same place, on the backside on the bend. Hammer on the surface sticking out with light to moderate blows, not always in the same spot. Keep your your hammering hammer and anvil hammer inline with the radius of the bend.
You'll see what I mean about the anvil absorbing the shock wave. It'll bounce away with every blow. You'll get a feel for where you get the mamimum bounce, indicating the most efficient effect. The aluminum will just bounce back without that.
Don't try to take it all out at once. It should take fifty to a hundred blows.
