newtong_ware
- Joined
- Sep 18, 2005
- 59
I am stumped.<br /><br />rebuilt carbs, have fuel flow, plugs are getting wet from fuel. found some trash at the float seat that was probably causing the rough running(surging). Yeah, you guys were right, rebuild the carbs...<br /><br />I have good spark at the plugs, the coil high and low impedance checks. <br /><br />i did put in a new key switch and safety kill switch, but they sure look right. The black yellow wire is grounded when the switch is off and/or if the safety kill switch tether is pulled. Other wise high impedance to ground. I even disconnected the black/yellow wire at the power pack, but still no good.<br /><br />It all looks right, but the engine won't start.<br /><br />Any suggestions folks?<br /><br />compression is good on all cylinders, although one is a little weak.
