Re: 115hp - Low Cranking Compression
You should test the cranking compression prior to purchase. Should probably be around 100 lbs on each cyl. A 10% variance between all cyls is acceptable. If one is less than 90 lbs it could be a problem. Might only be a head gasket, but could need a complete overhaul. Pull all 4 plugs out when testing the compression.
