115hp Mariner Outboard ignition problem
neznaika
Hi everyone! I have a 115hp Mariner O/M. I had it running this year once, but when I tried to start it again, i didn't get a spark on all cyl. I had a spark on 1-2-3-4 cyl. but after trying to figure out a problem (couldn't find anything) i had it on 2-3 cyl. only. What would be a problem? Thanks everyone!
Laddies
Banned
Re: 115hp Mariner Outboard ignition problem
I think that the way you describe it it's a 4 cyl but is it ADI or CDM ign, does it have a switch box or not?
Laddies
Banned
Both systems are CD does yours have a switch box or not? We can't help if we don't know the tests are differant for the two.
neznaika
Yes it has switch boxes, and a year I believe is 1981, 6 cyl. inline.
Laddies
Banned
That really helps, was it so hard? Heres the test info.
neznaika
Thank you, I'll try that! but let me ask you this, i talked to my friend and he said it could be the cracked wires on the trigger. What's your opinion on this?
Laddies
Banned
It's a possible but each trigger winding effects only 2 cyls. there are 3 winding so it's unlikly that 3 would fail at once.
neznaika
Ok, here's what i found out after performing those tests:
stator- blue to ground 140v
stator- blue/white to ground 140v
stator- red to ground 15v
stator- red/white to ground 15v
trigger:
black to yellow sleeve
brown to white 1320 ohm
white to purple 1320 ohm
purple to brown 1320 ohm
I also swiched green wire on the coil from 3rd(working cyl.) to 4th(non-working cyl.) i had a spark on 4th cyl. That tells me that the coils are good. Then i did other way arround and i had no spark on 3rd cyl. Looks like to power from switchbox.
What do you think ?
Laddies
Banned
Disconnect the kill wire to the boxes then, try swaping the input wires from the stator to the boxes, red to red/white and blue to blue/white and see if that changes the spark from odd to even number cyls as one side of the stator powers 1 box and the other powers the other. If that don't work disconnect the bios wire between the boxes.
neznaika
Kill switch is the one connected to mercury switch?
Laddies
Banned
On your engine it'e orange I believe the newer engines it's black/yellow and it connect to the same place the mercury switch does. When you OHMed the trigger it checks fine the stator checks a little low but is working and some times a slow turning engine will cause low voltage. I am afraid the switch box bios has failed.
neznaika
Thank you very much for all of your info and help locating the problem. I bought new switchboxes and everything went to perfect order. Before I put them on, I had a weak spark, but now i see huge difference. Thanks again.
