Hello there,
This is my first post, and I've done lots of searching, but just can't find my issue anywhere.
I have an old Skeeter with a MotorGuide trolling motor. I *had* a 12/24V charge switch up front, near the trolling motor plug, but the switch burned out. Not able to find a replacement, I decided to bypass the switch, as I had a 12/24V switch on my motor.
Finding the diagrams posted so often by SilverTip, I got everything wired up correctly, or so I thought. My first time on the water this season I found out that I have to use reverse to go forward, and vice versa. While this kind of works, it's sub-optimal and I'd like to get it fixed.
Now, since I *had* the 12/24V charge switch up front, I have four wires from the batteries up front - red, orange, and two blacks. I also have a 3 prong trolling motor socket/plug. I tied the two blacks together and wired them to the "center" leg, with red and orange on the others.
With a voltmeter, I get 24V across red/black, and 12V across orange/black.
How come my motor is running backwards? It didn't run backwards before the charge switch failed...
