Re: 12.5' with 9.8 running slow!
If the fuel line decomposed as it probably did, then there is a good chance that particles of foreign matter went into the carb. Cleaning the carb, any filter, and inspecting the reed valves would make sense. Is their any rubber hose on the motor itself? If so, has it also decomposed?
It does not take that much mechanical ability to put a kit in a carb if you follow some general guidlines. Do not force or bend any parts and work in a clean area. If there is a float drop measurement, make sure it is correctly set. Any rubber gaskets in the carb could well have been ruined by alcohol and require replacement. Tiny particles may be blocking small passages in the carb and will have to be cleaned out. Make sure any linkages to the throttle, etc are correctly made.
Sealing of the crankcase is of primary importance in a two stroke engine, so it should be checked if the carb work does not solve the problem.
If working on an assembly like this bothers you, pay a mechanic to do the work. You have enough time and money invested already, so you want to make sure the work is done right.
Three things have to be available for an engine to run. The proper amounts of: compression, spark, and a proper air to fuel ratio. A two stroke also requires oil in the gasoline mixture.
You are getting quite an education with the situation you are in. After it is solved, you will have an understanding of some useful things.
