luv2b0at
- Joined
- Jan 21, 2009
- 176
I was talking to a VFW comrade of mine regarding a couple outboard motors I was recently able to repair (thanks to some help from others on this forum, thank you.). He said I caould have an old Elgin motor he had stored for the last 30 years. It's a 12 hp 2 cylinder. He stores it properly. I was able to get it to sputter and run for a second or two, but that's all. I removed the carb, cleaned it and replaced it. It looks fine. I checked the diaphragm and it is very stiff. After the carb change, it's still the same. I have gotten it to run for 10 to 20 seconds but only if I butterfly the throttle. It is pumping water fine and it is not overheating. I am sure it's the fuel pump.
I guess my question is, where can I find the serial number so I can order some parts if any are available. There are part numbers all over the thing, but I cannot find a serial number.
If I can get it running reliably, is there any special value to this motor?
