Re: 12' sears game fisher restoration.
Hi Matt,
What I'm going to suggest may sound insane, but bear with me.
1.) You mentioned "waterlogged"... Step number 1 is to get the water out. If that were my boat, I'd bore a few holes in the bottom of the outer stern and prop the bow up as high as I could. Then I'd just let it sit and drain. Water is always the enemy, and if you can't get that out (IMHO), game over. Another choice may be to cut away parts of the inner deck and try to work from there. In any event, the water needs to go "by gosh or by golly."
2.) If there is wood, that needs to be ripped out. Wood holds water like a sponge.
3.) Once internal water is out of the way, you can consider glassing inside and out. Cracks can be patched and reinforced. The boat will probably never be pretty, but it should be usable.
Lastly, any boat can be restored to "showroom" or just functioning condition. Whether you want to spend "thousand$" in time and money on a boat that will ultimately be worth "hundred$" at best is a personal call.
Good luck,
Alan
