12 volt cranking and deep cycle bats
bently
When I purchased my boat it had a deep cycle battery for cranking. Is that ok or should I change it out for a regular cranking battery?
Thanks
Fireman431
Re: 12 volt cranking and deep cycle bats
Use a cranking battery for starting and a deep cycle for running lights/electronics/stereos, etc. Another option would be a dual purpose battery which combines the two.
Hubboat
It's probably fine, my friends boat I bought has a deep cycle for cranking. I heard no complaints from them.
I am going to run a couple DP (dual purpose) batteries when I swap them in.
bently
I was thinking a cranking battery would do a better job at spinning over the outbaord. I have a 1980 115 Merc "TOP".
bruceb58
I use a deep cycle battery to crank a 7.4L without a problem.
dingbat
I use a deep cycle to crank a 200HP outboard, no problem.
bently
Thank you all for all the info.
