120 evenrude won't restart
raftman
I have an 1989 Evenrude V4 120. It seems to start fine with just a little normal coughing and smoking. <br />After I have ran the engine for 10 to 30 min. and stop it does not restart. I have had to remove plugs and let them dry out, then it will start. It just won't start when its warmed up. Any suggestions for this problem?
raftman
Re: 120 evenrude won't restart
Still using vro. Should I remove and premix?
Solittle
Not so quick on removing the VRO as that may not be your problem. You said:<br /><br />"I have had to remove plugs and let them dry out, then it will start"<br /><br />That leads me to think:<br /><br /> http://www.outboardrepairs.com/carburetors/ <br /><br />When you get your motor running properly then think about pulling the VRO - I did on my 1987s.
raftman
I bought the boat from the former owners widow. She didn't have alot of information on the boat. I replaced the plugs with the correct ones and also installed new thermostats fuel filter and gas bulb. It ran fine at the lake last weekend. Good carb rebuild couldn't hurt.Thanks
