Trevornollmeyer
- Joined
- Jul 1, 2009
- 12
Please forgive me if I'm duplicating a post. I read several before deciding to post this and didn't see anything that applied to my situation.
The last time we had our boat out, I had trouble starting it. I'd turn the key and the starter wouldn't reliably engage. When I turned the key, it seemed like a dead battery; the starter would turn slowly and sound like it was cranking slowly. it would also only crank for a second or two at a time.
When it first happened, I was able to remedy the problem by tightening down the wing nut on the positive battery terminal. This worked several times until I couldn't get it started at all. We were nine miles up the lake on a week day with very few boats out-yikes. When I looked at the battery, the postive terminal was very hot. The wing nut appeared to have fused to the positive post. The two cables on the positive terminal weren't making good contact. I managed to get it started by using the battery cover to press down on the cables so good contact was made on the post. We made it back to our campsite. While cruising up the lake, the cable was making intermittent contact with the post, I'd see the guages working off and on.
Anyway, we got it started again and made it home. Once there, the threaded post on the positive side of the battery tore right out of the battery itself. There was some corrosion. I've replaced the battery and one of the cables/leads on the positive side. I cleaned up all of the cables with baking soda and some sandpaper. They all look good now.
When i got everything together, The starter still seems to crank slowly when I turn the key. I was able to start it in the driveway with some earmuffs and everything else electrical works great.
I'm guessing it's the starter or solenoid. I'm not all that mechanically experienced, so any help would be appreciated.
Thanks,
Trevor
Thanks,
Trevor
