120 hp Johnson starter won't connect with flywheel
Texhunt
Hi, I just bought an older model boat with a 120hp Johnson, when I try to start it, the starter just spins, does not connect with the flywheel. What do I need to do?
Thanks, Jim
McGR
As stated, make sure the battery is in good shape. Also, be sure all cables and connections are good. Additionally, check the helical splines on the starter drive/bendix. The drive should move freely along the splines. I usually use my secret concoction of WD-40 and graphite to lube the splines. Don't use any heavy lubes.
If none of these work, jump over the power cables on the solenoid with a suitable gauge cable (be careful, as soon as connection is made starter motor will spin...). If this corrects things, the internal contacts of the solenoid are in bad shape and the solenoid needs replacement.
Texhunt
Thanks for your replies, guys. I am pretty sure that the starter is about 5" x 7" mounted vertically under the flywheel, but I am not sure where the solonoid is and what it looks like. Help, please?
Thanks,
Jim
Texhunt
OK, I found a solenoid online, so I know what it looks like and can find it on the engine, but can I perform a test to determine if that is exactly what the issue is?
Jim
Eddie13
Texhunt it is most likely a gear reduction starter whereas the bendix on the starter does spin up like normal. The problem is under the flywheel cover. Do you have a flywheel cover with like a 100 bolts ???
I do not believe the 120 models were ever marketed with the 60 degree looper block.--The small 60 degree blocks had the gear down starter.----Load test the battery.----Take starter apart for cleaning , inspection , ohm check on armature.----No beer tokens spent to do this.-----Perhaps new starter brushes if all checks out.
Texhunt
Eddie, When I turn the key to start, the starter spins like crazy, but the bendix does not raise up to engage the flywheel. I have had a charger on the battery, and the light on the charger is solid, so I am pretty sure the battery is fully charged. Not sure about the flywheel bolts, I'll check. I posted numbers on previous post.
Jim
The MODEL number must be posted !----Numbers posted so far are no help at all.-----Or pictures of motor cowling and motor power head needed.-----You are sure battery is hooked up correctly?----You are sure that starter is assembled correctly?-----Did you see the motor run when you bought the boat / motor?
No geared down starter on that 1989 model 90 degree looper.----Does the starter motor turn counterclockwise when looking down on the starter , yes or no ?
Texhunt
Yes.
However, while I was turning the starter to answer this question, the bendix actually engaged the flywheel and I got it started for a few seconds. It is on a trailer and I didn't want to run it too long out of the water.
