120 hp Merc I/O outdrive won't stay down when locked in lock down position
redgoat
My 46-year-old Mercruiser outdrive will raise up when put into reverse gear even though the lock latch is in the lock position. This happens at slow speed as that's about the only time I use reverse. The engine will raise up a bit as though it is in the unlock position. Is there a simple fix for this? Do I need a new spring or what? My outdrive is so old that it does NOT have power trim. It just has a single hose hydraulic power tilt for shallow water and for trailering. Any suggestions?
Bt Doctur
Re: 120 hp Merc I/O outdrive won't stay down when locked in lock down position
sounds like the reverse lock is worn a bit. when shifted into reverse it should keep the drive from coming up.
Let me check some old stock. might even have it.brass item 2 inches wide and about 4 inches long
