120 hp merc rear mounting bolts
I forgot to take pictures of the rear mounting bolts of the motor mount.....i have a 1/2 inch(or so) spacer that i forgot where it goes.Can anybody give me some advice? I have a 120 hp merc, with a pre alpha outdrive...1971 silverline.....please help!
dubs283
Re: 120 hp merc rear mounting bolts
spacer on top of flange in flywheel cover mounting bolt hole, then large washer, then bolt
nut slides into slot on bottom side of inner transom plate mounting hole (may have to tape bottom side to hold it in place)
tighten bolt securely
Thanks dubs283....it all worked out perfectly! This site is so awesome...Agaain, a big THANK YOU!!!!
