120 I/L 4 / Sterndrive ID Questions
joey nathan
Gentlemen,
Have a possible reclamation project that I'm trying to identify for parts ordering, etc.
Appears to be 1983 vintage based on the hull number, but numbers missing from the out-drive.
So, is this an Alpha One?
Also, on the engine (6669253), I'm trying to figure out which exhaust tube/bellows to order because I've found two different part numbers (New Design 32-44348001 / Old Design 70981A3) for what appears to be the same item.
Many Thanks...
joey nathan
Re: 120 I/L 4 / Sterndrive ID Questions
Thank You Don
Appears to be 1 R - the first of the "Redesigned" models The serial number had been scratched off at the top of the unit.
I can order the exhaust bellows with confidence now!
