If some one could help. My 89 Bayliner Capri developed an overheating issue recently. I tried replacing the T-Stat, impeller, and flushing the motor. Soon after the motor started running poorly. I quickly removed the spark plugs to find water in all four cylinders. My first thought was to check the head gasket. Upon removing the head and inspecting the gasket, Im not convinced that this is the problem. I am not familiar with this engine(3.0 Force L-Drive) and would really appreciate any advice other than junking the boat. Also from what I can see the pistons and cylinder walls look ok.
