120 MC I/O trim tab
swandogg
I need to replace mine and it shows two available for it. One is zinc and the other aluminum. The one I had on there was zinc but am wondering if I should go aluminum if it would be stronger than the zinc one. Thoughts?
Bt Doctur
Re: 120 MC I/O trim tab
It`s not a matter of strength, it the corrosion protection offered. salt or fresh makes a difference.
swandogg
Gotcha. Only used in fresh water.
swandogg
Then you want magnesium
:confused: The only two I found available are either zinc or aluminum. I think I remember zinc's properties are close to magnesium so I guess that is what you are suggesting?
