120 Mercruiser removal and re-install
ljs22
I am forced to remove my mercruiser pre-alpha 120 completely due to having to replace my transom wood in my 1977 Starcraft Chieftain. Are there any hints not covered in the manuals that I should know? I am talking things like it looks like it would be a lot easier to install the lower shift cable before I set the engine in place. I know all about the alignment and stuff, but how do you check for a failing coupler? Any advice not covered in a service manual that might save time and aggravation is appreciated. I already have the out-drive removed, I am just looking at the transom plate and engine.
Good thing I know someone with a loader because those Chieftains are a lot taller them they look.
I wish I could afford the upgrade to the 4.3 but that is for another day.
coastalcruiser
Re: 120 Mercruiser removal and re-install
A bad engine coupler does not have flat spots in between the grooves when worn out they get pointed.
bigskiohio
If your going thu it all put new coupler in, save some work later.
On mine the rubber gave and melted so i dont think if i had looked at it 2 weeks before if i could tell.
