125 Force fuel pump
2902ao
Hello,
I have a 1987 Force 125 hp motor with the 2 stage fuel pump. The fuel pump has 3 check valves. Are all three of them the same valve? I cannot figure it out by looking at the manual. They all look about the same size, just one of them is turned around the other way. I only see one part number for these valves online.
john from md
Re: 125 Force fuel pump
All three valves are the same part number. Two are installed in one direction, one is installed in the opposite direction. The cost $5.50 apiece and two are easy to change, one is harder as you have to use a slap hammer or dremel tool to get it out.
John
