125 force head
stang1945
i have, as i was told a 1988 model.you can only make out the 125 on the tag so iam not sure.the head on this motor has cooling fins on it noticed the pics of the 1988 had a smooth head.is it possible this is a later model head.want to get a thermostat but the one for the 88 is to small.thanks for all the info so far has been right on. thanks jim
Frank Acampora
Re: 125 force head
Probably depends upon the model--A, B, C, D---My 1988 D version has the finned head. Internally, all the heads are alike so other than the cooling fins (which I don't think do too much) they all perform the same.
Usually, if the engine had a head with cooling fins, the exhaust cover had fins too. If the exhaust cover is plain, then someone replaced the head at some point, for whatever reason.
Back to the finned head: Think about this. The only air flowing through the interior is the intake air from the top rear opening of the hood. While it is significant at full throttle and high throttle settings, this air is not directed over the fins, so how much can they actually cool over and above the water in the jacket? maybe a couple of degrees?
stang1945
Re: 125 force head
mine has a finned exhaust cover so must be a D model.doyou know of anybody that has a thermostat for that model.there was none in it.thanks for everybodys help. jim
