Re: 125 force
check the first of this forum for stickys about cranking a sleeping motor, it's under repair and maintenance,engine frequently asked questions, by all means do the water pump impeller,lower foot lube change and if you don't know when it was changed last, the fuel pump diaphragm ,hope this helps
