hammbone_merc70
Thread starter- Joined
- Mar 10, 2010
- 6
tried to start the motor from a regular car battery. Should this work? if not how many cranking amps im I going to need to turn the motor over. I think the battery was stone dead, the engine did turn but not fast. Also is it common for the carbs to spew fuel when pressing the fuel bulb? And lastly does anyone know if there should be a little bit of oil in a tray under the bottom carb.? the tray has a hose hooked up too it... I'm not used to working on something the same age as myself.
