125hp lower gear case completely dry, no signs of leak, why ??
rubennh
Hi guys,
Today i was in the process of replacing the lower gear oil and when I pulled the plugs to drain the old oil, to my surprise it was completely empty and no signs of leaks around. She ran fine last season no issues at all.
Can somebody please tell me how is this possible?
Thank you so much!
CoffeeHound
Re: 125hp lower gear case completely dry, no signs of leak, why ??
What was the condition of the oil or was there any when you winterized the motor last year ? Fill it up and watch for leaks in the lower case .
Had that happen to a 9.9 back in the late 70's because i forgot to check for water in LU in Michigan !! Never forgot again !!
rubennh
It had oil before but now nothing ,I can't check the condition last time I went to the lake it was running fine.
Thanks
jerryjerry05
Sounds like the drain plug is clogged???
You wouldn't have gone far with no oil!!!
Small pointy something in the hole,maybe it will unclog??
Gotta be oil in there.
You sure you didn't drain it before or someone did it for you???
Come back and tell us what happened??
rubennh
Jerry,
Thanks for your quick response.
Nothing came out, I added more oil and only took 8 ounces to fill up, is that normal?
How much oil normally takes to fill it up all the way?
Thanks!
jerryjerry05
I think???? it takes about 32oz to fill.
Next question where you draining/filling it from???
ANY plug or screw and it should have gear oil comming out??
Post some pics?????
bentle
You should be able to add a full quart of oil to your lower unit.
Try and add a bit of gear oil with the drain plug out, and also does any oil drain out
after you added the 8 ounces ?
Like jerry said there has to be oil in there or you would have ruined the lower.
You are removing the screw on the very bottom back of the lower, right?
rubennh
When I pulled the drain and vent screws nothing came out, after I added 8 ounces of oil, started to come out of the vent, put everything back in place with
new o rings, no problem with that. Yesterday went to my closest lake ran for a good 3 hours no issues ,
no strange noises, everything seemed normal,got home pulled the screws again and guess what? Nothing came out,I really don't understand.
Why it took only 8 ounces when it normally takes 32?
I don't get it, where this oil is going to?
Appreciate your help guys!!
jerryjerry05
Tach and stuff 004.jpgTach and stuff 003.jpgYour not draining from the drain plug.See pic
The screw on the side(pic2) is a no-no.Make sure the bottom screw is removed.
Profile?? Location??
You should take it to someone who can help???
MJS
I changed my 1990 120 lower oil a couple weeks ago for the first time since ive had the boat. I drained and replaced. It took about a half of a quart to refill until it came out the vent. I checked it again after a couple trips to the lake, and it was still up to the vent. I assumed a half qt was good.
rubennh
Thanks.
catfishcarl99
i always remove both bottom plug and top. take a full 2 quarts ready. i stick tip on lower hole. squeeze the bottle till its as flat as i can get it. then remove it very quickly and stick in #2 and squeeze gently till oil comes from the top vent. then while holding pressure on oil bottle i put vent screw in. then remove bottle and quickly stick in lower. then tighten them. this assures theres oil from top to bottom.
rubennh
Thank you sir, got it, good to go now.
jerryjerry05
These can be bought here(I think).
Or at Wally's
For the novice.
The only way to fill the lower.J
