12hp Buccaneer runs like crap after rebuild
restornator
http://www.youtube.com/watch?v=62W8SXnJyj4
it ran before it had a knocking problem, which was apparently caused by the exhaust ports being plugged with carbon. all the ignition components are new, set, and produce a strong spark. The carburetor is from an 18hp and was rebuilt last Fall. Had to swap carbs because the original was set up for the onboard tank, which is not in useable condition. It pumps water like a champ, but that's all it does well. i just have no more answers for it.
jonesg
Re: 12hp Buccaneer runs like crap after rebuild
Great job on the video.
It looks like the problem is it will not take any throttle.
Carb is the problem, run it without the engine hood and try chocking it when you apply throttle, if it picks up rpm you need to get back into the carb.
There may be a carb issue, but at about 2:28 of your vid you can hear one cylinder cutting in and out. Check over your ignition again. I don't know about the suitability of the 18hp carb for this motor, maybe it will be fine, but you won't know 'til you get 'er firing on both jugs.
tashasdaddy
it would really help to know year or model #.
i do assume you have atleast 60PSI compression, on both cylinders, and they are within 10 psi.
sounds as if you have some carb adjustment problems,
http://forums.iboats.com/showthread.php?t=167352
also if you used the coil kits, that you have to put the boot on the end. strip back about 3/4 inches of insulation and wrap it in the spring connector. also make sure the center of the wire hit the pin in the coil connector.
also sounds like you need to link n sinc your timing.
steelespike
It appears to me its on one cylinder pretty much most of the time.
probably ignition.be sure points are clean and adj. to .020 on the highest point of the cam.Flywheel nut torqued to 480-540 inch lbs.bore and taper clean and dry.
Plug wires in good shape no rubbed thin/cracked spots.Be sure the coils are lined up with the bosses on the stator plate.
Also I think I detected a lean sneeze; carb issue.Repeatedly having to choke
is a clue.I would think the venturi on the 18 carb may be a little big.
Get her running on both cylinders and you may be able to adjust the carb enough to get it to run.
steelespike
Moderators to this point Gale,Bucaneer,Sea King have allways been in "other outboards."
restornator
both cylinders have 70 psi compression. model is 12S12 or 13B. first i wll crank it with my power drill and check the spark. Then pull the flywheel off and inspect the coils with relation to the mounting bosses. I'm thinking maybe i did something wrong rebluiding the intake manifold. I copied the gaskets from an 18hp but the crankshaft-facing gasket appeared to be different in the parts diagram. i will also reinstall the original carb and hook it directly to a tank that will be overhanging. The needle and seat cannot handle the pressure of the pump system
1946Zephyr
I think a carb from a 1956 OMC 15hp would be more suitable for this motor, since it is closer to that model than an 18.:cool:
You might also check and make sure your fuel pump is working good.
restornator
well i have that carburetor, so i might try it as well. Also have a nice fuel pump laying around
steelespike
who cares?? it's OMC, sharing many of the same parts
Yes; but if its considered an "other outboard" it may get more responses in that section.
Also anyone looking in "other outboards" for a thread to help them will miss this one
and some of the details the Gale gurus could supply.
Also the early Gales while a related family are indeed truly an "other outboard" so someone who thinks he has a Gale based motor isn't likely to look under E/J.
blakevan598
hey i have the same 12 hp buccaneer as in the video above is there anyway you could tell me the carb settings for this thing so i can get mine running thanks Blake.
Blake.vantrease@comcast.net
