Hello all I am new to iboats and I have a 12 hp wizard powermatic that will not shift into neutral.I started messing with the shifting level and thought it was in neutral fired it up and it ran full throttle and shot water everywhere haha. Anyway in tried messing with the lever again and forward and reverse works but it will not click into neutral. I looked at how it works and there is a small half moon with three small triangular cuts (to select what gear). Running down to the lower there is 2 set screws (two circular discs with 3 spiral teeth on them) that click together when I shift forward, do nothing when I put it in neutral, and when put it reverse they have about a 4 mm gap in between the screws. I am competent in mechanics but this is the first boat motor I've ever messed with ( I'm more into electronics)
Can anyone help me out please?
